Technical Discussions: Digital >> Scanning & Printing
Andra_M
Reged: 17/05/2009
Loc: Latvia
scanning of old photos - photopaper with texture
      #793295 - 17/05/2009 17:18
hello group,
I have a good quality photograph, and by my human eye when I look straight at it I cannot see anything particular about it. If I look at it sideways and closely then I see that the paper has a regular texture. But! the scanner is tooooo sharp-eyed, unnecessary sharp-eyed, and this texture appears in the scanned image. There are several scan options but not like “texture remove”. Is there a way to avoid the texture?
Scanner: CanoScan 8800F
FenModerator
BAD WOLF
Reged: 12/03/2002
Loc: London'ish
Re: scanning of old photos - photopaper with texture [Re: Andra_M]
      #793299 - 17/05/2009 17:25
May sound silly, but try turning the photo around 90° and scanning it again. It sometimes helps, but can't guarantee it
Fen .......... My Fen's AP Galleries - My Blog - My Flickr
- Joe Mcnally
zx9
Pooh-Bah
Reged: 22/06/2007
Loc: London
Re: scanning of old photos - photopaper with texture [Re: Fen]
      #793364 - 17/05/2009 21:04
Not knowing the Canon software, my reply is a bit of a guess but here are some ideas.
Are you scanning at too high a resolution? For prints as the original you do not need to use a very high resolution, all it will do is increase file size.
Has the software got a setting for aliasing / anti-aliasing? It could be that the line frequency of the scan is 'amplifying' the effects of the paper's texture.
Edit :
Is the scan software using USM sharpening? I find that by setting USM in Photoshop, I can 'pre sharpen' the image but not the grain, before doing any other editing. I would expect the paper texture could be reduced by pre-sharpening at say amount 200, radius 1, level 10. Some experimentation will be required but these settings are my starting point when trying to play down grain on the Epson.
It's a bit of a shot in the dark as I have an Epson and use it for scanning film, but hopefully a Canon user will turn up sooner or later.
Regards,
ZX9 (Keith Hudson)
Edited by zx9 (17/05/2009 21:16)
FenModerator
BAD WOLF
Reged: 12/03/2002
Loc: London'ish
Re: scanning of old photos - photopaper with texture [Re: zx9]
      #793365 - 17/05/2009 21:06
Keith,
It's not about the scanner. I've worked on photos like this before, they're are printed onto a textured paper and it's covered with lots of tiny dimples. I've found that changing the alignment of the photo can sometimes help in getting an image without too many of these dimples showing in the scanned version.
- Joe Mcnally
zx9
Pooh-Bah
Reged: 22/06/2007
Loc: London
      #793371 - 17/05/2009 21:34
Quote:
Keith,
Point taken Fen, I still think the surface texture is acting as a raster which could be reduced in the scan processing, after all moving the print a fraction (or by rotation) to reduce the effect is 'hardware' anti-aliasing.
In a 'lounge' discussion I would have said the OP should iron the print to reduce surface texture Thinking about it, fluid mounting should do it. Please do not try the last two.
Regards,
ZX9 (Keith Hudson)
Andra_M
Reged: 17/05/2009
Loc: Latvia
      #793605 - 18/05/2009 19:13
thank you both,
turning by 90 degrees didn’t help anything.
I tried different dpi and WxH in pixels – the texture (more or less visible as dots or actual pattern) is there. Actual size is 18x13 cm, on the screen it looks quite well when I zoom out till 6x4.5cm.
Image settings available:
1) Auto tone – ON, OFF
2) Set Unsharp Mask to ON - Sharpening slightly blurred images
3) Set Descreen to ON - Reducing gradations and stripe patterns
4) Reduce Dust and Scratches - None, Low, Medium, High
5) Fading Correction - None, Low, Medium, High
6) Grain Correction - None, Low, Medium, High
7) Backlight Correction - None, Low, Medium, High
8) Gutter Shadow Correction - None, Low, Medium, High
+ Color adjustment:
9) Adjusting Saturation and Color Balance
10 ) Adjusting Brightness and Contrast
11) Adjusting Histogram - a graph showing brightness distribution
12) Adjusting Tone Curve - a graph of brightness balance
13) Setting Threshold - Sharpening characters in text documents and reducing back-printing
cdhs
Reged: 15/04/2009
Loc: Swansea, UK
      #793703 - 18/05/2009 22:24
Unsharp Mask should be off and any other sharpening options. Sometimes placing something like a hardback book over the print and applying a slight pressure downwards on the book produces a better scan (leave scanner lid up)
Nod
Carpal \'Tunnel
Reged: 08/04/2006
Loc: Devon, UK.
Re: scanning of old photos - photopaper with texture [Re: cdhs]
      #793805 - 19/05/2009 11:07
I had the same problem scanning some pics for my Grandfather (from magazine type prints). I use a CanoScan 8000F so I suspect the setting will be similar. Under the settings tab in the ScanGear dialogue, check the Descreen box in the Filter Processing area; that should help reduce the regular blotchiness. IMO, all the other adjustments are better done in your usual PP software where you have more control. HTH.
MATWSIJ.....
Andra_M
Reged: 17/05/2009
Loc: Latvia
Re: scanning of old photos - photopaper with texture [Re: Nod]
      #793894 - 19/05/2009 17:44
It seems I'm leaving this as it is. Thank you, guys.
RogerMac
Hotshoe Shuffler
Reged: 25/03/2007
Loc: Reading
      #794048 - 20/05/2009 10:47
Sorry if I am butting in but I have found a similar problem with my scanner that can be bypassed by rephotographing the original image. Seems to avoid the problem completely and is a lot quicker than scanning
Roger
Edit: Typo
Edited by RogerMac (20/05/2009 10:54)
PHOTOSHOP ELEMENTS 8
Moderator:  Mat Gallagher, Damien Demolder, lisadb, Fen, Siuya, Benchista, Nigel Atherton, TheFatControlleR, AndrewC, mark_jacobs, daft_biker, Myk.R, Mike Lowe, OneTen, Hotblack, hhmr
Generated in 0.063 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression disabled.
