Steve
Enough of a twit?
Reged: 08/06/2005
Loc: York
Richard Sibley's "sparkling teeth" tutorial
      #783597 - 14/04/2009 19:05
Chaps, forgive me for being thick...but I'm going to ask this anyway...
Seeing as how Elements 6 does not have "Layer Mask", am I correct in thinking that the same result can be achieved simply by erasing the background/bits you don't want to change using the "Eraser" tool in the "Teeth" layer (to use Richard's example)?
Is the only difference that if you make a mistake using this method, it basically means you're screwed and have to start again...as opposed to being able to "paint white" over your mistake (as it says in the article)?
Sorry...not very good with PS...but want to make an effort to learn this stuff!
Steve
donny
member
Reged: 09/06/2005
Re: Richard Sibley's "sparkling teeth" tutorial [Re: Steve]
      #783741 - 15/04/2009 06:13
Not having seen the tutorial mentioned I cannot answer specifically , there may be some little twist in use that I am unaware of but in general you are correct in your assumption that the eraser tool on a new layer will give the same effect at the cost of being permanent.I am assuming that on a new layer you have lightened , brightened or saturated and now wish to remove specific areas.
Don
RichardSibley
AP Technical Writer
Reged: 03/08/2007
Re: Richard Sibley's "sparkling teeth" tutorial [Re: donny]
      #783837 - 15/04/2009 11:18
Steve,
Yep... if you are using Elements you can simply replace the layer mask step and erased the parts you don't need.
I would suggest setting the eraser to a low opacity - maybe around 15-20% and building up the effect. this should help blend the layers.
Obviously you will have to 'undo' if you make a mistake, rather than 're-painting' as you would do with the layer mask.
There is in fact a way of using layer masks with Elements. It will form part of the next Last Resort piece which is going to show a simple way of replicating a graduate ND filter effect. Look out for it in AP 2nd May.
Hope that helps
Steve
Enough of a twit?
Reged: 08/06/2005
Loc: York
Re: Richard Sibley's "sparkling teeth" tutorial [Re: RichardSibley]
      #783903 - 15/04/2009 14:42
Quote:
Steve,
Hope that helps
Thanks Richard. I will definitely look out for the next Last Resort (which, btw, is an excellent way to introduce PS dummies like me to some useful techniques!)
Steve
beejaybee
Marvin
Reged: 18/07/2007
Loc: Really Here In Name Only
      #784157 - 16/04/2009 10:49
If teeth were meant to sparkle, wouldn't God have made them of diamond?
john_g
Pooh-bah Hoo-ha
Reged: 09/05/2007
Loc: Surrey
      #784272 - 16/04/2009 17:17
I have to say that I get a bit miffed when I read any of the tutorials that say they are suitable for Elements users, but aren't. Another recent example was the one that detailed a novel sharpening method. Yes, I can now reproduce the effect using Elements, but only because I understood the principles and then worked out a different way of achieving the desired result. Before you publish any more such articles Richard, I'd hope you would load Elements on your machine and make sure that all the tools and techniques you've used are still available.
Oh, and if any Elements user wants layer masks (and who wouldn't?), then I'd suggest looking at the free layer mask add-on, available here:
http://graphicssoft.about.com/od/pselements/qt/layermasktool.htm
John
john_g
Pooh-bah Hoo-ha
Reged: 09/05/2007
Loc: Surrey
      #784276 - 16/04/2009 17:24
Steve, if you do the erase in little chunks rather than one epic effort, then you can always use Undo to recover any step that goes wrong.
The other approach I've found useful is to duplicate the layer that you are going to erase from, so you have two copies of it, and position these above and below the other layer that you're not intending to modify. That way, if you erase too much from the top layer, you can simply erase the equivalent area from the middle layer, revealing underneath the same image section as you've accidentally erased on the top layer. If you see what I mean.
John
Steve
Enough of a twit?
Reged: 08/06/2005
Loc: York
Re: Richard Sibley's "sparkling teeth" tutorial [Re: john_g]
      #784444 - 17/04/2009 08:17
Something else I have been thinking about is the option of the original photos being loaded to the internet somewhere so people like me who would like to learn the techniques can actually have a go to see if they can reproduce what Richard is trying to teach us
Steve
RichardSibley
AP Technical Writer
Reged: 03/08/2007
      #787351 - 27/04/2009 12:02
This weeks Last Resort (2 May) features a boxout on how to use Layer Masks in Adobe Photoshop Elements.
It is a little awkward compared to the full version of Photoshop, but once you have done it once, adding Layer Masks becomes relativley straightforward.
PHOTOSHOP ELEMENTS 8
0 registered and 5 anonymous users are browsing this forum.
Moderator:  admin, Mat Gallagher, Fen, Benchista, Siuya, Damien Demolder, lisadb, Nigel Atherton, TheFatControlleR, AndrewC, mark_jacobs, daft_biker, Myk.R, Mike Lowe, OneTen, Hotblack, hhmr
Generated in 0.06 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression disabled.
