Technical Discussions: Digital >> Scanning & Printing
 |  Print Topic Pages: 1
IKeepTrying
Reged: 04/02/2009
Scanning 127 negatives
      #757075 - 04/02/2009 19:18
I have an Epson V700 and am happy with it. I bought it to scan in negatives of irreplaceable family photographs which are now badly faded. 35mm and 120 negs are fine but the scanner kit had no holder for 127 negatives. Any suggestions about where I can get a holder or how I can scan the negatives?
mediaman
Nearly Laid Back
Reged: 28/07/2008
Loc: edinburgh
Re: Scanning 127 negatives [Re: IKeepTrying]
      #757096 - 04/02/2009 20:27
Seem to remember dev 127 film on a 35mm spiral..
and also mounting 127 slide film in "super slide" mounts,
which fitted into a standard 35mm projector.
You may find that The Widescreen Centre can supply the mounts...load them with the negs...and then try again with your scanner.[I assume your negs are square]
Hope this helps
Kenny.
BenchistaModerator
Which Tyler
Reged: 11/08/2000
Re: Scanning 127 negatives [Re: mediaman]
      #757205 - 04/02/2009 23:11
Nope - well, not on Paterson style one, anyway - they have three settings, the middle of which is for 127.
Certainly not all 127 negs were square, although the ones I still shoot (irregularly!) are.
Nick
www.nbrphoto.com
mediaman
Nearly Laid Back
Reged: 28/07/2008
Loc: edinburgh
Re: Scanning 127 negatives [Re: Benchista]
      #757217 - 04/02/2009 23:41
With hindsight, I should have looked up my records more carefully, [what few I have]It was 126 that fitted "Superslides" mounts...but,what if you made card 6x6 mounts, with the correct aperture cut out? Possable?
Kenny.
BenchistaModerator
Which Tyler
Reged: 11/08/2000
      #757221 - 04/02/2009 23:54
No, you.re right that some formats of 127 used superslide mounts - basically a 4x4 format - so it's still a possibility.
126 did also produce slides that could fit in a 35mm projector - 24mm square, from memory. Oh, and 126 could be developed in a 35mm reel.
Nick
www.nbrphoto.com
beejaybee
Marvin
Reged: 18/07/2007
Loc: Really Here In Name Only
      #757240 - 05/02/2009 00:37
I scanned a few 127 negs without a holder by trapping the edge of the film under a steel ruler to hold it flat. Scan the lot as one piece then use a marquee tool to isolate individual frames.
Roger_Provins
Made-it Man
Reged: 22/10/2005
Loc: Gloucester, UK
      #757256 - 05/02/2009 07:24
Have you tried laying the film on the scanner and then covering with a sheet of glass? Scan the lot in one go (takes a while at high resolution) and then crop out frames in PS. I've done this before and it worked well.
Rog
beejaybee
Marvin
Reged: 18/07/2007
Re: Scanning 127 negatives [Re: Roger_Provins]
      #757273 - 05/02/2009 08:46
Netwon's Rings
zx9
Pooh-Bah
Reged: 22/06/2007
Loc: London
Re: Scanning 127 negatives [Re: beejaybee]
      #757308 - 05/02/2009 10:23
If you had a lot of 127 negs to scan something like this may be useful better scanning I do have to say it is not something I have used, I just found it in my research whilst trying to decide if I should buy a V700.
Regards,
ZX9 (Keith Hudson)
Roger_Provins
Made-it Man
Reged: 22/10/2005
Loc: Gloucester, UK
      #757318 - 05/02/2009 10:41
Quote:
Netwon's Rings
Technically yes - but I never had the problem Try and see.
Rog
LargeFormat
Pooh-Bah
Reged: 24/10/2006
Loc: Cumbria and Buckinghamshire
Re: Scanning 127 negatives [Re: zx9]
      #757397 - 05/02/2009 13:49
Should be useful to a number of us - thanks.
IKeepTrying
Reged: 04/02/2009
      #757468 - 05/02/2009 16:19
Thanks to all of you - will experiment with your suggestions and report back.
Regards.
PHOTOSHOP ELEMENTS 8
1 registered and 7 anonymous users are browsing this forum.
Moderator:  Mat Gallagher, Damien Demolder, lisadb, Fen, Siuya, Benchista, Nigel Atherton, TheFatControlleR, AndrewC, mark_jacobs, daft_biker, Myk.R, Mike Lowe, OneTen, Hotblack, hhmr
Generated in 0.061 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression disabled.
