sacha
Reged: 20/10/2008
just what the title says, I was out doors taking some pics of some lovely vivid green mossy rocks and some autumn leaves. The colours in real life where so vivid and clear but when I put them into lightroom to view them... the colour just wasn't there it was like there was too much white, I would appreciate any help
Sacha
p.s using a nikon D40 with no filters and 18-55 lens
PhilW
Blue Peter Badge Winner
Reged: 14/03/2007
Loc: Near Wakefield, Yorkshire
We need more info to help.
Can we see an example? Were you shooting raw or jpg? If jpg what were the in camera settings?
-------------------- Phil Winterbourne
http://www.philwinterbourne.co.uk
benji
Reged: 12/12/2006
Is your shot over-exposed? Did you try and add saturation in post-processing? If you shoot RAW, try and adjust the white balance more to your liking maybe. As said above, without seeing the shot or having more details on your workflow/in-camera settings, it's difficult to help. Benji
-------------------- Benji BRISPN, CRISPS, SOTENVINEGA, CHIZENONIEN
Rhys
Sasquatch
Reged: 15/01/2004
I thought that as well. Can this be an Adobe-RGB versus an S-RGB thing?
-------------------- BSRIPN (Officially full of it..)
RGMP.co.uk (My Website.. getting there at last.)
TimF
Taking it strictly
Reged: 30/07/2001
Loc: Herts/Beds border
Lightroom's native colour space is actually Pro Photo RGB, which has a wider gamut than even Adobe RGB (it can be changed in Preferences).
Without more information my best guess would be that the OP needs to do some adjustment of Levels, contrast or whatever to get the pictures looking how they wish. A raw file is like an unbaked cake.
-------------------- Tim BSRIPN
benji
Reged: 12/12/2006
That's why tweaking your RAW file is always a good way of enhancing your image (just make sure you don't overcook it).
Benji
(I know...!!!)
DaveG40
Reged: 21/07/2007
Silly question, but hey it is me, what white balance setting did you have ?.
'Phantom' of the forum!
Reged: 03/04/2003
What ISO setting? You may have simply overexposed it.
-------------------- David.
Photos hosted by Flickr.
sacha
Reged: 20/10/2008
ISO 200
sacha
Reged: 20/10/2008
Here is an example of that washed out (white haze)look I'm getting
http://sacha83.deviantart.com/art/Forrest-road-103406432
would a UV or polarising filter help?
Sacha
Edited by sacha (13/11/2008 11:59)
sacha
Reged: 20/10/2008
by the way the details are as follows
Model: NIKON D40 Shutter Speed: 1/160 second F Number: F/5.6 Focal Length: 55 mm ISO Speed: 200
Benchista
Which Tyler
Reged: 11/08/2000
Sacha
No - if anything, a UV filter would make it worse. A decent lenshood would help, though.
Looks like you've got some veiling flare, which a lenshood adapted for the focal length in use would cure - although you might be better off with a French flag (a shading device on an arm that will prevent the sun from causing flare). Also, the contrast range of that shot is such that you're always going to have either/or burned out highlights (such as the bracken) and blocked-up shadows. Only way round that is with HDR or a similar process, as an ND grad won't work with a subject like that.
-------------------- Nick
www.nbrphoto.com
sacha
Reged: 20/10/2008
Thankyou so much that really helped
Sacha
Reged: 03/04/2003
Have you checked the histogram? A slight adjustment in levels using the mid slider might improve things.
benji
Reged: 12/12/2006
Sacha,
Nick/Benchista is right. Next time, to achieve the result you are after, expose for the hightlight areas of your image, and let the shadows go black (no other way round). At least you'll retain saturation in the highlights, which is what you said you were trying to achieve.
(basically, your in-camera lightmetre has compensated for the shadow areas present in your image. Do a spot metering on the highlights only next time, it should help. In-camera contrast set to a minimum should also help in such midday-light conditions)
Benji
sacha
Reged: 20/10/2008
Great advice, I'll head on down there today and try that out!
Thanks!
