Equipment >> Canon Conflab
Rupert49
Reged: 12/01/2008
Canon EOS 5D Mk II - battery compatibility
      #711903 - 28/09/2008 23:20
The recently announced Canon EOS 5D Mk II will use higher capacity BP type batteries (LP-E6) which will enable information about discharge and percentage remaining charge to be shown on the LCD. Does anyone know if the LP-E6 batteries (which have recessed terminals) can be charged on the Canon CA-PS400 dual charger? Will BP-511A batteries be compatible with the 5D Mk II? There may be a clue here in the fact that there is to be a new battery grip for the 5D Mk II in the form of the BG-E6 (my 5D uses the BG-E4), presumably because of battery differences ... anyone know the answer yet, please?
Little Fruitbat
Reged: 13/11/2005
Re: Canon EOS 5D Mk II - battery compatibility [Re: Rupert49]
      #711905 - 28/09/2008 23:39
I think they said the batteries were not compatible. No word on the charger, but I guess it's the same.
Happiness is a Kebab call donor - Pictures/Blog
Little Fruitbat
Reged: 13/11/2005
Re: Canon EOS 5D Mk II - battery compatibility [Re: Scphoto]
      #711909 - 29/09/2008 00:42
(the same as in it's not compatible, just like the batteries!)
John Baker
he can
Reged: 07/03/2003
Loc: Teignmouth, Devon
      #711916 - 29/09/2008 07:55
This may help...
Extract “Even though they appear similar, the previous-generation BP-511A batteries are not interchangeable with the new LP-E6 battery pack, and cannot be exchanged for one another. The new EOS-5D Mark II requires the LP-E6 battery pack, and cannot accept the older BP-511A or similar Canon batteries. Likewise, the new LP-E6 cannot be used in the previous EOS 5D, or other EOS bodies which accept the BP-511A battery pack.”
Rupert49
Reged: 12/01/2008
Re: Canon EOS 5D Mk II - battery compatibility [Re: John Baker]
      #712255 - 29/09/2008 23:12
Thanks John (and to others who responded) - the issue seems pretty unequivocal so I guess this thread stops here. Regards, Rupert
Done&rundleCams
Reged: 20/12/2001
Loc: Vancouver, BC
      #713056 - 01/10/2008 22:50
Hi Rupert,
I was just at a Canon Training show (for 5D Mk II and others) and found out an interesting
fact about the LP-E6 battery (and the new 5D) ... there is a serial number in/on the battery
and it will communicate with the camera so if you have several batteries you can put the
battery in the camera and not only tell how juice it has left (before needing charging) but how
much life the battery has before it is time to purchase a new battery
BTW, I should mention that this was in Vancouver, BC .
Jack
Life is a Photo-op
MY BLOG: www.nakedmanonawire.blogspot.com
Little Fruitbat
Reged: 13/11/2005
Re: Canon EOS 5D Mk II - battery compatibility [Re: Done&rundleCams]
      #713061 - 01/10/2008 22:59
Oh noes intelligent batteries, or in others words how Canon wants to stop you using better cheapo batteries from the net.
0 registered and 6 anonymous users are browsing this forum.
Moderator:  admin, GCW, Benchista, Siuya, huwevans, Fen, TheFatControlleR, Damien Demolder, AndrewC, mark_jacobs, daft_biker, Myk.R
Generated in 0.052 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression disabled.
