CSBC
News Editor
Reged: 24/11/2006
AP News
Going potty
Reged: 14/04/2003
Loc: Sussex-by-the-Sea
13.5Mp?!.....
Clearly pixel count still looks to be the the single most important factor in marketing compacts.
When, O Lord, when is one of the major manufacturers going to realise that there is a market crying out for far fewer but better quality pixels?
-------------------- Nigel
Completely BSRIPN
ElSid Gallery
Edited by El Sid (07/08/2008 09:10)
RovingMike
I had a dangly thing
Reged: 16/05/2006
Loc: Herts
Quote:
13.5Mp?!.....
Well that's why my next compact is likely to be the Panasonic LX3, which has stopped at 10.1 to let the low light / higher ISO performance catch up. The Nikon 5100 was a total dog at 400 ISO. I tested three in front of various photo shop ownwers against an £85 Canon A series and it lost by a mile every time with hopeless noise and poor colour rendition.
-------------------- Mike
My flickr site: http://www.flickr.com/photos/rovingmike/sets/
Avocadopearaphobe
Reged: 02/09/2002
Loc: Horwich UK
Looks like a useful camera to keep in the office and loan out to engineers for record shots while on site visits etc.
If it records the location where the shots are taken, at least you can nip out to the same place and do the job properly if the need arises ...
-------------------- Ian A
I can pan!
Reged: 21/06/2005
Megapixel haystack aside, I like the camera. It's got a proper viewfinder,records RAW and has a manual mode apart from all the other bits. Big thumbs up to Nikon from me.
-------------------- Regards,
Luis
My Flickr mess
huwevans
Old Hand
Reged: 05/08/2000
Loc: Dorset, UK
Yes, I'm interested. The high pixel count isn't ideal, but for low ISO shooting it might be worthwhile. As the ISO climbs the real limt on image quality isn't so much having too many pixels, but having not enough square inches of sensor.
chromatin
Reged: 26/06/2008
Loc: NE Lincs
Quote:
...the real limit on image quality isn't so much having too many pixels, but having not enough square inches of sensor.
That's a bit like saying "I'm not fat, I'm just too short for my weight"...
-------------------- My Flickr Photostream
RovingMike
Reged: 16/05/2006
Loc: Herts
If you had done the side by side tests I did a month ago, you'd be horrified at the fall-off in quality at 400 ISO. Happy to post a comparison if anyone wants, but will dent your faith in Nikon. This features-chasing should not be at the expense of the basics that the tool needs to deliver.
huwevans
Old Hand
Reged: 05/08/2000
Loc: Dorset, UK
Sorry, but nothing I've said is an issue of 'faith', but of directly relevant technical knowledge and expertise. Everyone knows that quality falls off as ISO increases - that's not under dispute. What I meant by the statement you quoted was that total signal-to-noise ratio (which is essentially what 'image quality' meant in the context of rising ISO) is not very much affected by pixel count. Both signal and noise are integrated over area in the final printing/viewing process, and pixel density effectively disappears from the equation. The Mk 1 eyeball, coupled with the brain's signal processing, integrates locally, with groups of pixels or dots on the paper merging together to produce a general impression of details, tones, etc. plus whatever visible noise there is.
So for fixed reproduction size - certainly for common print sizes - and assuming similar technology, pixel count isn't actually terribly important - the total signal is more or less the same, and the total noise is more or less the same. Only by improving the original signal level, either by reducing the ISO and giving more exposure or by increasing the sensor area, is that parity significantly disrupted.
Put it another way - gien two sensors of the same receptive area, and the same basic technology, but one having, let's say, 6MP and the other having 12MP, then if you either interpolate the larger file down to 6MP, or interpolate the smaller one up to 12MP, the resulting images will be fairly similar in their noise levels. Expect some difference, certainly, in favour of the lower original pixel count, but that difference will be relatively small when compared to the difference made by actually increasing/decreasing the sensor area, because that, rather than pixel count, is the real limiting factor as the ISO setting rises.
IvorETower
Little Buttercup
Reged: 15/11/2006
Loc: Camberley, Surrey
You don't half pay for all that, though. Have you seen the RRP ???
-------------------- Too many cameras, too many lenses.......
RovingMike
Reged: 16/05/2006
Loc: Herts
Thanks, but if that's the case I can't excuse the 5100's awful performance on any grounds. I was quite shocked to see a model I had persuaded myself would be the ideal purchase struggling so poorly and seeing the emphasis given in the replacement to everything except picture quality, gives me little hope that they have improved things.
Just did the same comparison with the Leica Digilux 3 and that beats the things that beat the 5100....by a long way.
huwevans
Old Hand
Reged: 05/08/2000
Loc: Dorset, UK
Well it probably would, wouldn't it - for precisely the reasons I discussed above. The Digilux 3 has a 4/3" sensor, which is huge by comparison to the 1/1.7" sensor of the P5100 - about 6x the receptive area. What did you expect?
RovingMike
Reged: 16/05/2006
Loc: Herts
Sorry, mean the D-Lux 3. 1/1.65 CCD according to the spec.
huwevans
Old Hand
Reged: 05/08/2000
Loc: Dorset, UK
Okay, well that's more surprising. The D-Lux 3 is (I think it's widely believed) identical under the skin to Panasonic's LX2, which has a fairly poor reputation for noise.
Howbeit, it's still not really relevant. To cross-compare and draw deductions specifically about the effect of increased pixel count alone you'd need to fix all the other variables. That means you need the same sensor technology and the same processing. Comparing cameras from different manufacturers with different sensor techinologies, different processing engines, and different processing algorithms means that you cannot tell what is responsible for the end result from the output alone.
The mathematics and signal processing theory underlying the point I made about the sensor area being the limting factor as the ISO rises is beyond dispute. What it means is that for high ISOs, as the noise levels rise, it doesn't really matter very much whether the manufacturer put 13.5MP on the sensor or 10MP. For the same technology, processing, and so on, the final information content will be pretty much the same - only improvements in the hardware (so that less electrical noise is generated) or the sensor area (so that less 'shot-noise' is present in the signal itself - the light falling on each photosite) will result in real gains.
Going potty
Reged: 14/04/2003
Mechanically and optically I think they pretty much are the same but IIRC the image processing side is different. I imagine that the Leica probably is as noisy as the Panny but I would strongly suspect that the noise-reduction routines in the Leica are more sophisticated in terms of maintaining resolution and detail. I know from my FX30 that the NR routine can be a bit heavy handed (and patchy). TBH I've come to the conclusion that sometimes the 'noise problem' is actually made worse/more obvious by rather clumsy attempts to alleviate it...
Completely BSRIPN
ElSid Gallery
huwevans
Old Hand
Reged: 05/08/2000
Loc: Dorset, UK
Well I certainly leave all noise reduction options set firmly to 'off' - but then I have a DSP background! :-) Ultimately there is no difference between an electron that gets counted because a photon hit the sensor and one that arose from some electrical or other noise source - the camera or software cannot possibly know which is which. So all post-processing noise-reduction efforts inevitably process out detail as well as noise, because by that time they are quite simply the same thing.
One can potentially use some sort of subject recognition algorithms to spot things like, say, a clear blue sky, and then apply noise reduction more heavily in such areas, confident that there won't be much real detail lost. But that kind of approach almost inevitably runs the risk of producing 'cartoony' images. I'd rather my pictures were just noisy! :-)
As with grain on film, I think we still have pretty much the same three options, and for the same fundamental reason - keep the ISO low, get a bigger format camera, or learn to love it! :-)
RovingMike
Reged: 16/05/2006
Loc: Herts
Interestingly when I tested the DLux3 it had very low noise at ISO 400, but entirely failed to register small-ish areas of red. One shot had a fan in it with circle of 6 stars on the front, five black and one red. The red one came out grey. Also in another shot was a pic on teh wall mostly momo, but with a neon bar sigh in red. It also came out grey, with no tinge of red. Was in Jessops at teh weekend and the guy told me he never recommends the Nik 5100, because of complaints about picture quality. It is (was) a real dog.
