Equipment >> Pentax Chat
GrahamR
Reged: 13/11/2006
Pentax 10-17mm Fisheye
      #685159 - 31/07/2008 11:50
Hi all,
I have now had my fisheye for around a month, and really like this lens.
Its so creative, you can really produce some unusual results.
The purple fringing is a problem though.
The lens is really sharp and produces nice results abouve f8.
A lens I can recommend for your Pentax/Samsung.
Gromit
enthusiast
Reged: 03/06/2008
Loc: Sunny Swansea, UK
Re: Pentax 10-17mm Fisheye [Re: GrahamR]
      #685166 - 31/07/2008 11:56
Can we see some results from it?
'Phantom' of the forum!
Reged: 03/04/2003
Re: Pentax 10-17mm Fisheye [Re: Gromit]
      #685220 - 31/07/2008 13:52
Can you reduce the fringe effect in PS Camera raw?
David.
Photos hosted by Flickr.
old'n'grumpy
Reged: 12/07/2006
Loc: somewhere in Sussex
      #711675 - 28/09/2008 08:35
If you look on my DeviantArt page at some of the Cowdray pics (full size), you can see the purple fringing clearly. If I try and correct it in PS (lens distortion correction) then a green fringe appears on the other side of the object!
Other than that it really is a great lens, any ideas on how to remove the fringing greatly appreciated though......
Growing old disgracefully!
AlexMonro
Reged: 05/06/2006
Re: Pentax 10-17mm Fisheye [Re: Dave_Cox]
      #711715 - 28/09/2008 11:10
I've had some sucess using this GIMP script. It works by locally reducing saturation of the fringing colours around high contrast edges. Of course, you'll need to download the GIMP in order to run the script, and it adds another step to post processing, but I have found that it reduces the PF in some of the shots from my Fuji S9500 (which is quite bad at wide angle) from "annoying" to "unnoticeable" on medium szed prints, say 10x8". And because of the way that it works, it's unlikely to introduce new artefacts.
johnriley1uk
Reged: 08/06/2006
      #711719 - 28/09/2008 11:41
It will depend also on the type of subject - branches against sky are a particular problem. In extremis I make a monochrome conversion and that obviously totally eliminates the problem.
Best regards
John Riley
Going potty
Reged: 14/04/2003
Loc: Sussex-by-the-Sea
      #712011 - 29/09/2008 13:16
Quote:
...any ideas on how to remove the fringing greatly appreciated though......
There was a lens supplement in AP a while back that had a couple of handy tips.
One is to create a saturation adjustment layer, select the magenta colour range then using the dropper options select the exact colour of the purple fringing and desaturate using the slider.
Another method suggested is to duplicate the image and blur the duplicate layer by 5 pixels. Change the blend mode of the duplicate to Colour and the original image reappears largely minus the fringing. In the AP article this was mainly aimed at red fringes but I find it also works on purple.
One issue with both methods is that they can adversely affect other parts of the image so what I tend to do is apply a mask and paint on the mask to reveal the adjustment only where it's needed.
Another method I have used is to create a blank layer set to Saturation mode and then paint with black, on this layer, over the fringing which desaturates it. Fine control can be achieved either by painting at less than 100% brush density or by lowering the layer opacity afterwards.
PS
Something on your deviant art link generates an error message in IE7 about a script causing the browser to run slowly and or crash (it crashed). Don't know whether this affects other browsers or just IE7 but might need looking at...
Completely BSRIPN
ElSid Gallery
old'n'grumpy
Reged: 12/07/2006
Re: Pentax 10-17mm Fisheye [Re: El Sid]
      #712284 - 30/09/2008 06:30
Thanks Nigel
I'll try some of those tips next time i use the lens.
BTW - I use IE7 and the DA link works fine....
Going potty
Reged: 14/04/2003
      #712389 - 30/09/2008 12:50
Does for me now.....maybe our server was having an off day.
Completely BSRIPN
ElSid Gallery
Generated in 0.055 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression disabled.
