Equipment >> Pentax Chat
attack_donut
member
Reged: 16/12/2006
Loc: East Coast
Sharp lens in the 28-90mm range?
      #682573 - 24/07/2008 15:22
I'm in need of one for my GX-1L, I'm really confused by all the nominclature out there (DG? EX? FA?) and could use some guidance.
I would like a really sharp lens, I have some dedicated macro lenses for my k1000 that function in manual mode just fine on my dSLR, but the other lenses I own range from modest to downright fuzzy when it counts, and I feel i'm at the skill level where this is holding me back...
Suggestions/comments are welcome.
Cheers!
Storms arise and eclipse the sun, the march of kings has begun.
johnriley1uk
Reged: 08/06/2006
Re: Sharp lens in the 28-90mm range? [Re: attack_donut]
      #682772 - 24/07/2008 23:57
The SMC Pentax-DA 16-45mm f4 is a superb lens at a currently very modest price.
The SMC Pentax-FA 24-90mm is also superb if you can find one.
FA lenses cover the full 35mm frame. DA lenses cover the reduced image circle of the APS-C sized sensor.
Best regards
John Riley
'Phantom' of the forum!
Reged: 03/04/2003
Re: Sharp lens in the 28-90mm range? [Re: johnriley1uk]
      #682870 - 25/07/2008 11:10
The Sigma 17-70 (25 to 105 Equivalent) is a good quality lens at a reasonable price. It has been well recommended on here by several Forum members including me.
see this
David.
Photos hosted by Flickr.
Going potty
Reged: 14/04/2003
Loc: Sussex-by-the-Sea
      #682933 - 25/07/2008 12:49
The Sigma and Tamron 18-50 f2.8 lenses have plenty positive comments on these forums. Sigma's 17-70 is also a very capable performer.
If you're not set on a zoom then prime lenses are always top performers with that old favourite the 50mm still being amazing value for money in image quality.
Completely BSRIPN
ElSid Gallery
Reged: 03/04/2003
Re: Sharp lens in the 28-90mm range? [Re: El Sid]
      #682971 - 25/07/2008 13:49
Prime lenses wear your shoes out quicker....
David.
Done&rundleCams
Reged: 20/12/2001
Loc: Vancouver, BC
Re: Sharp lens in the 28-90mm range? [Re: Monobod]
      #683063 - 25/07/2008 16:55
buy cheap shoes and lots of them
Jack
Life is a Photo-op
MY BLOG: www.nakedmanonawire.blogspot.com
attack_donut
member
Reged: 16/12/2006
Loc: East Coast
Re: Sharp lens in the 28-90mm range? [Re: Done&rundleCams]
      #683117 - 25/07/2008 19:30
Thank you kindly.
I do have a pair of dedicated (prime) pentax macros for my old k1000. A 100/f4 and a 50/f2.8 (I think it's 2.8) which are nice lenses, but the 100/f4 is all manual and I don't think the aperture will properly adjust (in other words, I can manually set it to 22, but I'm not seeing any difference between f22 and f4) whereas the 50 is an "a" and will adjust DoF nicely.
Can these things be used for anything other than macro? in other words, can they be used as an "everyday" lens?
Reged: 03/04/2003
      #683130 - 25/07/2008 20:36
Yes, I have the Pentax 100mm F/2.8 Macro (1:1) lens and it is fine for portraits or enything else, see here:
Flickr Page 7
All of the boat and river shots along the Wey are taken with this lens.
David.
Going potty
Reged: 14/04/2003
      #683982 - 28/07/2008 17:15
IIRC, and I'm sure a proper Pentaxer will be along to confirm or deny, but with fully manual lenses yo have to go into the custom menu and find a particular function which is called something like 'Enable Aperture Ring'... When set to the correct value I think this then allows the camera to read the position of the aperture ring when metering and to stop the lens down to the correct aperture on exposure.
HTH
Completely BSRIPN
ElSid Gallery
Pooh-Bah
Reged: 05/02/2007
Loc: Edinburgh
      #683987 - 28/07/2008 17:47
HTH
Indeed. The OP's Samsumg is basically a K100D (I believe) - so go to the custom settings menu, enable aperture ring, and set preview to 'proper' stop down, rather than 'digital preview.' Then, in M mode (can't speak for the others 'cos I don't use them) set aperture on lens, quick twist the on/off switch to the right, and the lens stops down. It'll show the 'correct' exposure (centre weighted mode) as 0.0 or over/under exposure as anything between -3.0 and 3.0. Adjust as desired. I have set the AE-L button to quick shift the shutter speed to the 'correct' value for my given aperture. This works really well, much quicker than this description would make it sound.
Zou's Flickr Page
welshwizard645
Reged: 29/09/2006
Loc: Out of my mind
Re: Sharp lens in the 28-90mm range? [Re: Zou]
      #684983 - 30/07/2008 22:16
It's actually the *ist DL2 , but I guess there is not much difference in the user interface between the DL and K100D/S....
The OP likes his 2.8 lenses, and my DA*16-50 is sharp...That's what I would recommend. BUT, here's the BUT, to get the best of the DA* lenses you have to have the K100D Super, K10D, K20D or K200D (for SDM)...
If you can find one the FA 24-90 is Superb (FA is Pentax's line of film SLR AF lenses). The Sigma DC 17-70 has its fans. I have a Sigma EX 24-70 (EX is Sigma's pro line) which is a really good lens.
welshwizard645
Reged: 29/09/2006
Loc: Out of my mind
      #684984 - 30/07/2008 22:17
HTH
Yes, you can do that, it's an easy thing to do to allow the camera to use pre-A lenses....
attack_donut
member
Reged: 16/12/2006
Loc: East Coast
Re: Sharp lens in the 28-90mm range? [Re: welshwizard645]
      #687002 - 05/08/2008 15:53
Huh-
Had the M setting set in the BIOS of the camera, but didn't know about the turning to the right of the on/off switch, that makes all the difference. Thanks!
Generated in 0.059 seconds in which 0.007 seconds were spent on a total of 12 queries. Zlib compression disabled.
