AP Magazine >> Help Team
Jump to first unread post. Pages: 1 | 2 | >> (show all)
snowqueen
Queen of the castle
Reged: 12/06/2008
Loc: Balcombe,Sussex
shutter speed?
      #679713 - 17/07/2008 01:28
can someone please tell me (before i go mad!) how i keep the shutter open to photo moving cars, i was trying to capture the lights of the car, it kinda worked but the shutter only stayed open for a few seconds? i wanted to leave it open for 30 second?? im using a nikon d80 and have read the manual on trying to do this and played around but (maybe im stupid) i still cant work it out???
thank you
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return.
old'n'grumpy
Reged: 12/07/2006
Loc: somewhere in Sussex
Re: shutter speed? [Re: snowqueen]
      #679720 - 17/07/2008 06:29
Presumably you're doing this at night. Put the camera in a tripod, set it to a low ISO setting, aperture priority at about f11-f16 and fire it by using the timer or a remote release. Works for me.
Growing old disgracefully..!
Roger_Provins
Made-it Man
Reged: 22/10/2005
Loc: Gloucester, UK
      #679722 - 17/07/2008 06:39
I don't have a Nikon but I expect the answer is to set the mode dial to M mode (manual) then using the main command dial/wheel set the shutter speed to bulb. This will keep the shutter open for as long as the release button is kept pressed or, much better, you will need a shutter release cable that is lockable in the on position - and, of course, have the camera mounted on a tripod.
Rog
john_g
Pooh-bah Hoo-ha
Reged: 09/05/2007
Loc: Surrey
Re: shutter speed? [Re: Dave_Cox]
      #679723 - 17/07/2008 06:45
I'd say that, if you want 30 seconds and not, say, 8 seconds, then put the camera into shutter priority mode (I assume the set speeds go as slow as 30 seconds, most do) and let the camera set an appropriate aperture. But you might find that, even on the lowest ISO setting, there's too much light coming from street lights etc. - in that case a neutral density (or even a polarising) filter can help to cut the light down and give you the possibility of longer exposures. Oh, and the ISO setting generally wants to be as low as possible, as that will help keep exposures long.
Another thing to try is second curtain flash with long exposures. The 'second curtain' setting means the flash will fire at the end of the exposure, instead of the beginning, and so you can catch the blur of the car with a 'frozen' image of it captured just before the shutter closes. But not a good idea if you're just taking pictures of random cars on a public road!
John
And the day came when the risk to remain tight in a bud was more painful than the risk it took to blossom - Anais Nin.
snowqueen
Queen of the castle
Reged: 12/06/2008
Re: shutter speed? [Re: john_g]
      #679754 - 17/07/2008 09:12
Thanks everyone.....i did use a tripod, set a low iso and even put it on bulb, but still didnt get the effect i wanted??the sutter stayed open a few seconds? this is the photo i got, not quite what i wanted...
PhilW
Blue Peter Badge Winner
Reged: 14/03/2007
Loc: Near Wakefield, Yorkshire
      #679762 - 17/07/2008 09:28
The bulb mught be the issue - on my camera, in bulb, you press and hold the shutter, and release aftr your desired exposure - if you just clicked and released that would explain it.
Phil Winterbourne
http://www.pbase.com/calis
ham888
member
Reged: 11/06/2008
Loc: Worcestreshire
Re: shutter speed? [Re: PhilW]
      #679771 - 17/07/2008 09:42
Snowqueen, I have a D80 also. If its in M then set to bulb then the shutter should stay open for as long as you hold the shutter.
Just tried it in fact and thats what it did. Are you using a remote release it may be different with that?
Harry
snowqueen
Queen of the castle
Reged: 12/06/2008
      #679772 - 17/07/2008 09:42
I think thats what happened in a few? so if i put on bulb and timer would that work or not? if i dont use bulb is there another option?
Thank you
beejaybee
Marvin
Reged: 18/07/2007
Loc: Really Here In Name Only
      #679773 - 17/07/2008 09:44
What did you expect? The image is pretty similar to what I'd expect to get with that technique.
Maybe you should try somewhere without high-intensity road lighting
PhilW
Reged: 14/03/2007
Re: shutter speed? [Re: beejaybee]
      #679778 - 17/07/2008 10:01
The easiest method is to shoot in Shutter priority mode and just select the time you want (up to 30 seconds) as John said above.
Phil Winterbourne
Nod
Carpal \'Tunnel
Reged: 08/04/2006
Loc: Devon, UK.
      #679780 - 17/07/2008 10:08
Thank you
For exposures up to 30 seconds, there is another option - in S mode (shutter priority) set the shutter speed to the setting you want (longer settings (over a second) are signified by " after the figure). Same thing in M mode - and here, you'll be able to select the aperture you want as well. You can also use the "B" setting in M mode but you'll need a remote release to avoid camera shake. Using the ML-L3, the first press of the button opens the shutter, the second closes it again. If you have "Long Exposure Noise Reduction" switched on, don't forget that the camera will take a similar time to your exposure to complete its noise reduction.
MATWSIJ.....
snowqueen
Queen of the castle
Reged: 12/06/2008
Re: shutter speed? [Re: Nod]
      #679783 - 17/07/2008 10:20
Quote:
Thank you
Ive been playing with the camera and ive just found " so set it to 30.......i put a 2 sec timer on and on the first press of the button the timer comes on, but u see nothing in view finder, then after about 8 sec it opens and stays open for maybe 12 seconds........does this sound right? will try tonight when its dark! not ideal in my bedroom!!
thanks for ur help
ham888
member
Reged: 11/06/2008
Loc: Worcestreshire
      #679785 - 17/07/2008 10:30
Could you explain what you mean by "2 sec timer"
Harry
Nod
Carpal \'Tunnel
Reged: 08/04/2006
Loc: Devon, UK.
      #679786 - 17/07/2008 10:32
Not sure about the D80 - got the manual downloaded but not the camera - but tried the same thing on my D70. Shutter speed set to 30", self timer on. Press shutter release; after 10 seconds, shutter opens for 30 seconds (viewfinder balcked out). With your shutter speed set to 30 seconds, I would expect your shutter to stay open for 30 seconds.
MATWSIJ.....
snowqueen
Queen of the castle
Reged: 12/06/2008
Re: shutter speed? [Re: ham888]
      #679787 - 17/07/2008 10:41
I meant self timer.....sorry
john_g
Pooh-bah Hoo-ha
Reged: 09/05/2007
Loc: Surrey
      #679788 - 17/07/2008 10:42
On the D80, is there a safety shift type of thing which will override the settings if that's going to result in over/under exposure? This might be a reason why you tell it to open the shutter for thirty seconds and it does something else.
I'd not use the self-timer at all until you're happy that the camera is doing what you expect - all it does is delay the opening of the shutter and, although this can be useful to reduce camera shake, with a thirty second exposure a bit of movement at the very beginning isn't going to be catastrophic.
Try a thirty second exposure with the lens cap on (instant darkness!) and, if this works as expected, repeat it with the lens cap off and see whether the shutter open time stays the same as before.
John
daft_bikerModerator
Action Man!
Reged: 11/10/2006
Loc: Doon the glen
      #679794 - 17/07/2008 10:59
Could be right....the headlights in the pic are probably a bit too bright already. It maybe that the scene is simply too bright to allow for a 30 second exposure.
Snowqueen - do you have a polariser? You could fit that to make things darker and give you a longer shutter speed. (ideally a ND (neutral density) filter would be used to darken things for longer shutter speeds but a polariser might do the job).
Another common subject to try longer shutter speeds on is moving water....do you have a stream or river nearby? (although I admit I am a bit of a sucker for blurry water )
EDIT - also, did you use f/22? Normally I wouldn't want to stop down so far but for this kind of thing I'd make an exception.
Andrew (BSRIPN) ... Pics.
Edited by daft_biker (17/07/2008 11:04)
john_g
Pooh-bah Hoo-ha
Reged: 09/05/2007
Loc: Surrey
Re: shutter speed? [Re: daft_biker]
      #679828 - 17/07/2008 12:42
I looked in the manual on Nikon's website - the camera can be set so that it shifts the ISO sensitivity if needed, but this is off by default and I couldn't see anywhere that it could override the selected exposure settings, so this is probably a maroon mackerel.
John
ham888
member
Reged: 11/06/2008
Loc: Worcestreshire
      #679838 - 17/07/2008 13:18
I think thats called Auto Iso (number 7 on the pencil menu). Must admit I thought that in M mode the camera just did whatever it was told ~ i.e no overide to control exposure
Harry
Steve52
Reged: 08/04/2007
Loc: Dawlish, Devon, UK
      #679947 - 17/07/2008 18:29
Hi Snowqueen
I haven't tried this sort of photography yet, so cannot add any advice. However, I thought I'd just say I like the picture, espcially if you crop out most of the black. (Sorry MODS, I know its not Exhibition or Appraisal).
FRIPN. Nostalgia just isn't what it used to be.
0 registered and 34 anonymous users are browsing this forum.
Moderator:  admin, GCW, Siuya, Benchista, huwevans, Fen, Damien Demolder, Nigel Atherton, TheFatControlleR, AndrewC, mark_jacobs, daft_biker, Myk.R
Generated in 0.093 seconds in which 0.014 seconds were spent on a total of 13 queries. Zlib compression disabled.
