School of Photographic Imaging >> Diploma in Digital Photography
hil26
Reged: 07/11/2007
Loc: North Wales
Module 4
      #672236 - 29/06/2008 09:03
Got to here and the third course image to manipulate, and although I know that it's all subjective, having carried out various adjustments in curves following the tonal segments part on P34 of the course book; using layers for the curves adjustment, turning it off, and comparing with the original, I cannot see an improvement. Is it my eyes?????
Garry McNamara
Snr Tutor/Bongo Banjo
Reged: 16/08/2006
Re: Module 4 [Re: hil26]
      #672321 - 29/06/2008 16:11
Depends on what you've done with curves, can you see the difference here?
If not you need to look a bit harder - it can be tricky at first - try applying the adjustment to a small selection so you can compare original with adjustment at the same time or make a copy and adjust them side by side. Take your time studying them,
Garry
hil26
Reged: 07/11/2007
Loc: North Wales
Re: Module 4 [Re: Garry McNamara]
      #672466 - 30/06/2008 08:28
Garry
many thanks for that tip, hadn't thought of comparing it that way, although when pointed out it's one of those that should have been apparent.
Moderator:  GCW, Benchista, mark_jacobs, Siuya, Damien Demolder, AndrewC, huwevans, TheFatControlleR, Fen, Course_Admin, daft_biker, Myk.R
Generated in 0.078 seconds in which 0.008 seconds were spent on a total of 12 queries. Zlib compression disabled.
