Equipment >> Nikon Chat
mjc7uk
Am I banned yet?
Reged: 08/07/2006
A new owner of Nikon 70-300mm VR....
      #672108 - 28/06/2008 20:04
...could anyone give me a guide on?
Am taking it to the Air Show at RAF Waddington this coming weekend, and I would appreciate if anyone would shed a light on as which switches I need to use on my recent purchase Nikon 70-300 AF-S VR Lenses.
(My 40th Birthday treat to myself!)
So which I should be using the "normal" or "active" when I attempt to span the taking off/landing of any aircraft?
The Nikonboy is back...
We can't stand about here doing nothing. People will think we're workmen. - Spike Milligan.
lightspeed
Reged: 17/09/2006
Re: A new owner of Nikon 70-300mm VR.... [Re: mjc7uk]
      #672293 - 29/06/2008 12:56
Hmmm....Quite fancy this lens myself!
I assume it will be the same as the 18-200/VR lens that I use. Use the "Normal" setting.
The "Active" setting is only for when you are taking pictures from a moving vehicle (which I assume will not be the case?)
Set "M/A" switch to "A" for Autofocus mode
photogeek
Professor Yaffle
Reged: 02/01/2007
Loc: Londonish
Re: A new owner of Nikon 70-300mm VR.... [Re: lightspeed]
      #672623 - 30/06/2008 13:29
Great Lens, use it with my D300 and the 1.5 multiplie makes it fantastic for wildlife as it is small and light enough to handhold and the VR makes that work. Set the D300 to a highish ISO 400/800 and you get speed, perfomance and very little noise.
Be yourself you know its true and in the end whats left is you.....
surf_digby
Reged: 04/04/2008
Re: A new owner of Nikon 70-300mm VR.... [Re: photogeek]
      #673907 - 02/07/2008 21:23
Are you going to be panning as the plane goes past? If so, you'll need the active setting.
Nod
Carpal \'Tunnel
Reged: 08/04/2006
Loc: Devon, UK.
Re: A new owner of Nikon 70-300mm VR.... [Re: surf_digby]
      #674112 - 03/07/2008 11:20
Sorry but that's wrong. Active mode is for use when taking pictures FROM a moving vehicle.
From the lens's manual...
Setting the vibration reduction mode switch
NORMAL: The vibration reduction mechanism primarily reduces
camera shake, making smooth panning shots
possible.
ACTIVE: The vibration reduction mechanism reduces camera
shake when taking pictures and those from a moving
vehicle. In this mode, the lens does not automatically
distinguish panning from camera shake.
and...
• When taking panning shots, be sure to set the vibration reduction mode switch to
[NORMAL]. If you move the camera in a wide arc when panning, vibration in the
direction of that movement is not affected. For example, if you pan the camera
horizontally, only vibration in the vertical direction is reduced, making smooth pans
much easier.
MATWSIJ.....
mjc7uk
Am I banned yet?
Reged: 08/07/2006
Re: A new owner of Nikon 70-300mm VR.... [Re: Nod]
      #675131 - 05/07/2008 22:02
Thanks to everyone and I am pleased to say that the Nikon 70-300mm work nicely with the setting at Normal.
It does bring me pleasure to see my photographs...
Will post it soon.
Thanks once again.
CANON LAUNCH 15MP EOS 50D
Read AP's view on the new high-end enthusiast EOS 50D
1 registered and 47 anonymous users are browsing this forum.
Generated in 0.118 seconds in which 0.009 seconds were spent on a total of 12 queries. Zlib compression disabled.
