davidmurray
Reged: 03/06/2008
photoshop elements catalogue backup
      #662550 - 04/06/2008 11:17
Hi All, this is my first post. I have looked to see if this has been dealt with.
When I backup with a full backup PS Elements 4.0 onto an external hard-disk the files are copied, but with new filenames, which do not relate to the ones I gave them on my puter hard-disk. So this means that I have my images backed-up, but - so far as I can see - without filenames, tags etc.
Is it that the metadata is there, but I can't see it. Or am I doing something wrong in the backup ?
Craftysnapper
enthusiast
Reged: 05/01/2006
Re: photoshop elements catalogue backup [Re: davidmurray]
      #662700 - 04/06/2008 17:04
No your not doing anything wrong and all the info is there, if you need to re install the backup at any time Elements will assign the original file names and all the tags and captions as long as you instal it from the organizer.The reason it uses numbers is in case you have duplicates with the same file name in different folders like say the same image for the web with the same file name.
My Glass Is 4/3rds Full
Paul
davidmurray
Reged: 03/06/2008
Re: photoshop elements catalogue backup [Re: Craftysnapper]
      #662983 - 05/06/2008 10:39
Thank you. Good news is a rare thing. But surely this means that the files are copied onto the external hard drive, but the PSE itself - which in the event of retreiving these files would assign the original names to them - is on the puter hard drive. So that if I lost the puter then I would also loose the data which would restore the copied files.
I find good news hard to believe !!!
Norman
Reged: 23/09/2004
Loc: West London, UK
      #663158 - 05/06/2008 12:42
That's true of pretty much all backup software. You need to install the operating system and the backup program before you can restore the data. You could try making disk images with something like Ghost or Acronis though.
Regards,
Norman
www.photobox.org.uk
A woman has the last word in any argument.
Anything a man says after that is the start of a new argument.
Craftysnapper
enthusiast
Reged: 05/01/2006
      #663202 - 05/06/2008 13:24
No the copied files and the data would be on the external harddrive then it would just be a matter of re-installing them to a new computer/or new internal HD after re-installing Elements.
Paul
FIRST LOOK: CANON EOS 5D MARK II
Barney Britton takes an early look at the Canon EOS 5D Mark II, a new 21.1-million-pixel, full-frame DSLR that offers more than just an upgrade on the popular EOS 5D
0 registered and 13 anonymous users are browsing this forum.
Generated in 0.112 seconds in which 0.015 seconds were spent on a total of 12 queries. Zlib compression disabled.
