Technical Discussions: Film >> Traditional Darkroom
Wilwahabri
Reged: 28/02/2008
110 film storage
      #618372 - 28/02/2008 16:55
I know 110 is thought to be a poor option but I load my own cartridges with Velvia 100 and process in a Jobo processor and using the Pentax auto 110 and Minolta 110 Zoom cameras the results are bordering on amazing when compared to 110 print film processed by a commercial lab.
My problem is storing the film strips. Does anyone know of a supply of 16mm (110 is baisically 16mm film) film storage pages or hanging files?
Gepe still manufacture 2 x 2 slide mounts for 110 so that isn't a problem but I generally keep the fim as strips and scan with a modified holder in my Minolta Scan Daul IV scanner
Tacitus
History
Reged: 17/01/2006
Re: 110 film storage [Re: Wilwahabri]
      #618414 - 28/02/2008 18:49
I make my own envelopes out of high quality, archival grade, bleach free (etc) paper. An A4 sheet cut into 2x A5s with a few folds and 2 staples or Sellotape to secure the ends works fine. A ream of this paper is not expensive (per sheet) and will last a lifetime. I do the same, but larger, for 35mm & 120 negs.
Admittedly these are then just stored in a small 'shoebox' with a bag of silica gel (changed regularly once every ten years ).
I guess the d-i-y envelopes could be slid into a 35mm album style system if necessary .....
domroberts
Reged: 13/07/2000
Loc: Kent
Re: 110 film storage [Re: Tacitus]
      #618492 - 28/02/2008 21:26
We use heavy-duty 35mm sleeving which holds 110 in strips of six quite nicely. They can move around a little bit but it is not problematic. PM if you are interested and would like me to divulge our supplier name but the item code 735H.
Dom Roberts
CANON LAUNCH 15MP EOS 50D
Read AP's view on the new high-end enthusiast EOS 50D
Moderator:  admin, GCW, Benchista, Siuya, huwevans, Fen, Damien Demolder, TheFatControlleR, AndrewC, mark_jacobs, daft_biker, Myk.R
Generated in 0.101 seconds in which 0.007 seconds were spent on a total of 12 queries. Zlib compression disabled.
